Stryker - 840
by Stryker
Cast Cutter
A tough, long lasting, easy-to-use cast saw.
-Chris-CBET
a year ago
Need Cam tool
I'm working on a unit, similar to the stryker 840 (AO 0295-200), and i can't remove the bearing from the armature nor the armature. I see there is a cam tool to remove it but it's discontinued. Does anyone have 1 or have another idea for replacing it?
-fred toolman
6 years ago
need a print wiyh part numbers
can i get a print of a striker 840 cast cutter having problems getting parts without part numbersReply
Length 10.5 in
Weight3.7
Diameter: 2.75 in
Electrical: 120V AC 60 Hz 2.0A 1/5 HP
