Hillrom - Likorall 243 Overhead Lift
Strong lifting capacity
The Likorall 243 overhead lift system provides strong and secure lifting for those who need enhanced lifting power. The lift motor is installed in our standard rail system and has a lifting capacity of 507 lbs (230 kg). Like the other ES-class motors, the Likorall 243 ES system allows for movement of the lift motor along the rail electronically with a transfer motor, or to control the rail's electrical switches via a wireless hand control option. Its safety features include a patented safety drum with speed limiter and electrical emergency lowering.
The motor’s 200 cm (80 inches) lifting interval handles lifts from the floor in most environments, and the motor can be equipped with a special carriage for easy room-to-room transfers. A quick-release changing sling bar adds to its appeal.
Speed limiter
Patented safety drum with speed limiter.
Planned transfers
Can be equipped with a special carriage for planned transfers between different rooms.
Hand Control
Wireless hand control option.
Lifting interval
Lifting interval 200 cm (79 in) - handles lifts from the floor in most environments.
Charging
Simple wall charging via hand control or, alternatively, charging from the ceiling rail.
Emergency Lowering
Electrical emergency lowering.
