Hillrom - FlexoStretch Lift Stretcher
by Hillrom
Flexibility for the care environment
The FlexoStretch lift stretcher is a versatile and flexible horizontal lifting accessory that can adjust to accommodate patients of nearly every size. Its sturdy aluminum construction and high maximum load of 660 pounds makes it especially useful in handling heavier patients.
The weight-bearing section of the FlexoStretch lift stretcher may be used with either a full lift sheet (the LiftSheet XL) or five lift straps (LiftStrap XL 80/XL 100), which are placed under the head, shoulders, back, seat and calves.
The width of the FlexoStretch lift stretcher can easily be adjusted to between 28-38 inches by pulling its lift arms out or in. This makes the FlexoStretch lift stretcher an excellent choice for both normal-weight and bariatric patients.
Max Load
The maximum load is 300 kg (660 lbs). Because of the aluminum design, the FlexoStretch lift stretcher weighs no more than 14.5 kg (32 lbs).
The FlexoStretch lift stretcher can be used together with one of the overhead lifts: Likorall, or Multirall, or one of the mobile lifts: Viking XL, Viking L or Golvo.
Quick-Release Hook
The lift stretcher can be installed with a fixed connection (screw and nut) or with Liko Quick-Release Hook System. The latter requires the lift to be equipped with the Q-link fastener or the Quick-release Hook Adapter.
Easy to Adjust
The width of the FlexoStretch lift stretcher can easily be adjusted to between 70 cm (28 in) and 95 cm (38 in) by pulling its lift arms out or in. This makes the FlexoStretch lift stretcher an excellent choice for both normal-weight and bariatric patients.
