Hillrom - LikoStretch 1900 Lift Stretcher
by Hillrom
Safe and quick lifting
Transferring patients horizontally can be a challenge. The LikoStretch 1900 lift stretcher helps caregivers move patients safely and quickly. The LikoStretch 1900 lift stretcher is a versatile horizontal lift accessory designed with simplicity in mind.
The lift accessory also facilitates patient care by lifting the patient during hygiene maintenance or changing of the bed sheets without manual lifting or manipulation by the caregiver.
Quick-Release Hook System
With the Quick-Release Hook System the lift stretcher can be installed easily without tools. With the included lift stretcher leveler you can easily adjust the lifting so that the patient lies either horizontally or somewhat higher at the head end.
Easy to Handle
The fact that LikoStretch 1900 lift stretcher weighs only 19 kg (42 lbs) makes it easy to handle for one person. It can also be folded for convenient storage.
Lift Sheet
You can choose between a full or a 2-piece lift sheet. The 2-piece lift sheet can be especially suitable in connection with, gynecological, as an example, operations as the lower part folded up out of the way.
Self-locking Feature
The lift sheet is attached to the stretcher by inserting the straps in the self-locking feature, which is closed with light pressure. The lift sheet can be either placed on the bed before patient already lying down.
