Hillrom - OctoStretch Lift Stretcher
Maximizing space during horizontal lifting
The eight-armed OctoStretch lift stretcher is one of our most popular horizontal lift accessories, suitable for use in surgical, ICU and radiology departments. The OctoStretch lift stretcher is easy to operate and has a small footprint that makes storage simple.
The OctoStretch lift stretcher can be used with a full lift sheet (available in different sizes) or with 4-5 lift straps, which help provide better access during hygiene maintenance procedures. If the patient cannot be turned to the side, HandySheets can facilitate the application of the lift sheet.
Easy to Handle
The OctoStretch lift stretcher is very light: weighing just 7 kg (15 lbs), and has a maximum load of 200 kg (440 lbs). It can be used with many different lifts in Hill-Rom's Liko lift portfolio.
Quick-Release Hook
The lift stretcher can be installed with a fixed connection (screw and nut) or with Liko Quick-Release Hook System. The latter requires the lift to be equipped with the Q-link fastener or the Quick-release Hook Adapter.
