Fujifilm - Dri-Chem NX500i
by Fujifilm
Dry chemistry analyzer
FUJI DRI-CHEM from FUJIFILM is a dry chemistry analyzer which can perform multiple test parameters of Clinical Chemistry. It has a built-in auto-pipetting system, requires no calibration and no water, providing easy preparation and maintenance. The new FUJI DRI-CHEM NX500 delivers results using a simple 3-step procedure. With its quick, easy operation and compactness, ""Real Time and Borderless"" Clinical Chemistry is made possible.
FORUMSView All (6)
-JTuria
7 months ago
Black plate Soiled
The Fuji dri-chem NX500i analyzer was showing black plate soiled. Clean black plate. Using the manual procedure, I have clean the black plate but the display of black plate soiled on the screen is still showing. What's the next step?
Equipment: FUJI DRI-CHEM NX500i
-MBAKA
2 years ago
USER MANUAL
KINDLY ASSIST WITH A SOFT COPY OF USER INSTRUCTION MANUAL FOR DRI CHEM NX500Reply
-Kuadey
4 years ago
ERROR CODE E0140
Hello Everyone, how do i resolve error code E0140 on my Fujifilm - Dri-Chem NX500i. Reply
Simple 3-step procedure
Fully Automated Procedure
1 step - Set the slide (Dry Slide Reagents)
2 step - Set the sample
3 step - Press START
No Parameter Input Required
Information of the parameter is incorporated in the bar code printed on the back of every slide.
No pre-treatment of sample required
Plasma Filter (PF) can cut the turn around time and the pre-treatment process of the sample. It can generate plasma sample by aspirating and separating the whole blood inside the PF within 1 minute. Just set the PF on top of the sample tube and press START.
1. Have the PF card read in the designated analyzer.
2. Set PF on the top of sample tube. - (A)
3. Press Start.
4. Suction unit move to be connected on PF and start aspiration of whole blood.- (B)
Easy operation by touch screen
# 5.7 inch VGA, 640  480
# Qwerty touch Key board. Basic Mode /Advanced Mode are available according to user preference. (Basic Mode: displays operation procedure for one sample only. Advanced Mode: displays operation procedure for one sample and measurement status for previous measured samples.)
Only 10μL/Test
# Each test needs only 10μL of sample. (CRP needs 5μL/test, ISE needs 50μL/3 tests). Manual pipetting can be also performed when less sample available. Less invasive for newborn at NICU.
No calibration required* QC card system
# A magnetic card called QC card will adjust the lot variability in the slide reagents.
# A QC card comes with every reagent box.
# The analyzer memorizes the lot adjustment information once a QC card is swiped. No need to swipe QC in every measurement for the same slide lot.
Accurate and reliable test results from long term and field-proven technology & experience
Minimize the risk of biological hazard
Measurement testColorimetry 28 tests
Electrolytes 3 tests
ThroughputColorimetry 120 test/hour
Combined 128 test/hour
Number of sample rack1
Number of incubator cellColorimetry 12, Electrolytes 1
Measurement timeColorimetry 2 to 6 minutes/test,
Electrolytes 1 minute/3 tests (Na, K, Cl)
Sample typePlasma, Serum, Whole blood
Sample volumeColorimetry 10μL/test,
Electrolytes 50μL/3 tests (NA, K, Cl), CRP 5μL/test
Data transmission to PCUSB 2.0 or RS-232C Serial
D-Sub 9 pin -9 pin cross cable
Data printThermal Printer
Electrical requirementsAC 100-240V, 50/60Hz, 2.5-1.1A
Dimensions470 (W)  360 (D)  420 (H) mm
WeightNX500 Approx. 25kg, NX500i Approx. 24kg
Operating temperature15 to 32°C( 59 to 89F)
Operating humidity30 to 80%RH
