Hillrom - Transport Stretcher
With its 700 lb weight capacity, our Transport Stretcher is an economical solution to help accommodate all patient conditions as well as your needs in this uncertain environment.
A rush to the operating room is not just about running down hallways and turning corners. It’s about the minute details that contribute to a safe and comfortable experience for both you and your patient.
A safe and comfortable patient experience
- Help prevent pressure injuries through your choice of pressure redistribution surface.
- Protect your patient's hands with bumper protected side-rails.
- Provide a gentle patient ride with spring-loaded Steering Plus system.
- Allow for safe patient ingress and egress with low height.
Simple and safe maneuvering
- 360° Maneuvering with Steering Plus system.
- Simple to activate bake and steer.
Durability and safe maneuvering
- 700 lb weight capacity.
- Compatibility with most lifts and over-bed tables.
- Easy to clean smooth deck and side-rail design.
- Power washable.
Maximum weight limit | 700 lbs (317.5 kg) |
Low position (floor to top of sleep deck) | 20.7" (52.58 cm) |
High position (floor to top of sleep deck) | 34.25" (87 cm) |
Overall length | 83" (210.8 cm) |
Overall width (siderails up) | 32" (81.3 cm) or 36" (91.4 cm) |
Overall width (siderails stored) | 30.38" (77.15 cm) or 34.38" (87.31 cm) |
Siderail length | 48" (121.9 cm) |
Siderail height above sleep deck | 14" (35.6 cm) |
Comfortline mattress size | 26" (66 cm) x 75" (190.5 cm) or 30" (76.2 cm) x 75" (190.5 cm) |
AccuMax VPC mattress size | 26" (66 cm) x 76" (193 cm) or 30" (76.2 cm) x 75" (190.5 cm) |
Maximum head elevation | 90° |
Maximum Trend/Reverse Trend | 18° |
Floor to base clearance | 3.5" (8.9 cm) |
Caster size | 8" (20.3 cm) |
Warranty |
Frames & welds for life of product |
Three-year parts |
Two-year mattress |
One-year labor |
