Mizuho OSI - Modular Table System
by Mizuho OSI
Designed to easily interface with a  C-arm
The Advanced Control Base is the primary component of the Mizuho OSI Modular Table System. It is designed to easily interface with a  C-arm and be utilized with three, interchangeable tops which are specifically designed to support patient positioning for a variety of surgical procedures.
FORUMSView All (5)
-JLZH
4 years ago
Preventative Maintenance Checklist.
Hello Does anyone have the Preventative Maintenance Checklist? Thanks in advance.Reply
-Matt D.
4 years ago
OSI 5803 rotation motor drive assembly
Who might have a good rotation motor drive assembly they would like to be rid of. My unit has about an inch plus of movement when the Dr. leans against the tableReply
-Matt D.
6 years ago
Support for for 5292
Looking for parts support for this unit. It was mad obsolete by OSI in 2016. Starting to have issues with it drifting down after being raised and lowered. It's intermittent right now but I have a feeling the controller board is developing a bit of leakage through the motor drivers preventing hold or breaking voltage. Reply
– Dual column design, easy C-arm access
– I-beam retractable for ease of storage
– Designed for use with gimbaled, Mizuho OSI modular tops
– AC and battery operation
– Powered lateral tilt and table articulations
– Hand Pendant controls Height, Lat
Height27 in 27 in  48 in. (69cm.  122 cm.) dependent on table system
Length 102 in
Tredelenburg 15 degrees
Lateral Tilt25 degrees
Patient Weight Capacity500
Width32
