BC Group - ESU-2050P
ESU Analyzer - Very Hight Accuracy - Pulse Measurement - External Loads
Designed through extensive collaboration with several of the world's leading electrosurgery generator manufacturers (including the worldwide market leader), the ESU-2050 is a highly accurate calibration-quality instrument intended for use by OEM factory technicians and field service engineers. Customers who desire to test their ESU generators in the exact same way the medical device manufacturers do can also use it. It is one of the only ESU Analyzer's with a 1% reading level of accuracy.
The calibration quality analyzer uses external precision non-inductive test loads and wideband current transformer. The standard model is compatible with all legacy generators with continuous output waveforms, and with the latest technology generators such as the Covidien Force Triad©, Ligasure Blood Vessel Dealing generator, etc. The standard model is NOT compatible with generators that produce pulsed output waveforms.
- True RMS readings using DFA® Technology
- 1% measurement accuracy
- Uses external current transformer & loads
- mV, mV Peak, mA, crest factor & wattage displays
- Waveform capture, storage, display & download
- Graphical display with bright white backlight
- Price includes: Universal Power Supply, Soft Carrying Case, RS-232 & USB Communication Cables, BNC to BNC Cable (3-foot) for Current
- Transformer connection, PC utility software
