Beckman Coulter - Avanti J-20 XP
The Beckman Coulter Avanti J-20 XP is a durable and safe floor centrifuge
durable and safe floor centrifuge with advanced control of temperature, speed, and friction. It can reach speeds up to 26,000 RPM and maintains an operator-set internal temperature between -10 to 40 degrees Celsius. If the temperature exceeds the programmed parameters, the Avanti J-20 XP automatically shuts off, preserving rotor life and sample integrity. All settings (speed, time, rotor identification) are shown clearly on the digital display or through the positioning of analog knobs next to the screen.
Other features include a friction reduction system (FRS) comprised of a vacuum pump that reduces the pressure inside the stainless steel rotor chamber to 190 mmHg, eliminating air friction for efficient operation. Also, it contains an on-board timer to program continuous or limited use up to 180 minutes.
0Replies3 years ago | D8 Drive Error Anyone had this issue before, machine was just serviced a week ago and was working perfectly.Reply |
2Replies5 years ago | Trying to locate manual I am trying to locate a service manual on this machine. Reply |
- Large-volume processing
- Accommodates up to six 1L bottles
- Up to 26,000 rpm and 82,000 x g
- Smart FRS (Friction reduction system)
- Accelerated throughput, shorter run times
