Haemonetics - OrthoPAT
by Haemonetics
It eliminates the need for pre-autologous donation ("PAD") programs and returns a higher quality blood product than allogeneic, PAD, and unwashed systems. The OrthoPAT system supports a "collect first" approach by allowing the recovery of shed blood when it's unclear how much the patient will bleed. With the ability to attach to a processing set, the QuickConnect Reservoir becomes a safety net; so, the surgeon returns the highest quality blood only to the patients who need it, and collect blood cost-effectively for those who don't. In short, the OrthoPAT system ensures the avoidance of unnecessary allogeneic transfusions for every patient. Like other blood salvage devices, the Haemonetics orthopat system collects and cleanses red blood cells lost during and after surgery, but it is the first product of its kind designed specifically to adapt to the perioperative, intermittent blood loss of orthopedic surgical patients. The system consists of single-patient use disposable sets and an electromechanical device which together collect and process red blood cells. For orthopedic patients, surgical blood salvage with the orthopat system means a reduced need for donor blood and a lowered risk of receiving excess fluids and contaminants often associated with other autotransfusion techniques.
0RepliesSun May 19 2013 | Patient What is used to collect the blood during total knee replacement? I know what OrthoPat will do with it, but how does it get there? Reply |
1ReplyFri Apr 08 2011 | Orthopa What will I do as a nurse to stop excessive draining from the orthopats or if the orthopats has washed a lot of blood? Do I clamp it for an hour?tnxReply |
[list] [*] Dynamic Disk technology that changes size according to blood volume loss and provides a consistent hematocrit in the reinfusable blood product [*] Intraoperative and postoperative salvage in a single disposable set [*] Easy loading disposable set [*] Full automation that requires minimal operator interaction [*] Continuous display of the volume of collected fluid [*] Small and highly portable device that mounts to an IV pole and is easy to transport, clean, and store [/list]
Technical Information - Base Unit 8 in. x 10.5 in. x 11.5 in. (20.3 cm x 26.7 cm x 29.2 cm) - Weight 20 lbs (9.2 kg) - Voltage 100 to 240 volts - Fuse Rating F2.5A @ 250V - Operating Frequency 50 or 60 Hz - Power Cord Length 15 ft (4.5 m) - Battery 30-minute Rechargeable Nickel Metal Hydride - Certifications ETL listed - Mounts onto Standard IV Pole - Processes up to 2 Liters of Fluid per Hour
