Biotec Fischer - TurboScan
Densitometer
TurboScan uses the latest digital image analysis technology. The advantages to you are obvious: analysis only takes a fraction of the time and the results obtained are reliable with excellent reproducibility. At the same time, TurboScan is based on commercial hardware components. The advantage to you-you can use existing PC hardware and save costs.
In terms of flexibility, TurboScan allows you to create as many individually generated scan masks as you wish. You can also select as many analysis methods as you wish. In clinical work, for example, you can use TurboScan for analysis in the following application: serum protein electrophoresis, Hb-A1 electrophoresis, urine electrophoresis, CSF electrophoresis, Bence-Jones, iso-enzymes, iso-electric focusing and lots more. It does not matter whether you carry out your methods on dry or wet cellulose acetate strips, on agarose, and on other gels or you work with micro, semi-micro or macro application.
- Universal and flexible analysis equipment for the clinical laboratory
- Analysis programs and analysis masks can be individually defined
- Irrespective of filters, special light sources or staining methods
- High resolution and excellent reproducibility
- High analysis speed
- Extremely simple to handle and comfortable to use
- Reliable, reproducible results
- Analysis results clearly displayed on the monitor
- Clear printout of results
