DRE - Integra SP VSO2 Portable
by DRE
Anesthesia Gas Machine
The DRE Integra SP VSO2 is a fully-functional, compact and portable anesthesia system in a lightweight package. The Integra SP VSO2 anesthesia system is compact enough for the smallest surgery or imaging suite, and is fully portable. Easily transport the DRE Integra SP VSO2 by using the retractable handle, located conveniently on top of the unit. Side-located gas ports allow clinicians to safely and efficiently set up the machine.
0RepliesTue Dec 19 2023 | PM report Checklist does somebody out there has PM report Checklist Reply |
2RepliesWed Oct 04 2023 | OEM certified Hello, Do you need to be OEM certified to work? PM thos machines ?? |
2RepliesMon Jun 27 2022 | Auxiliary O2 attachment Hi there. I have a question regarding the proper inlet adapter for the auxiliary O2 source. This port is located on the opposite side of the DISS O2, nitrous and medical air connector. Im not sure what adapter to order for the proper fit of a O2 flow meter to be attached to this source. Do you have any idea what it is? I have the options of 1/8 female or DISS hand tight. Thanks so much. Reply |
| Height | 13.8 in |
| Gases | Oxygen, Air |
| Length | 7.9 in |
| Weight | 26 |
| Width | 19.7 in |
