GE HealthCare - Aestiva/5 MRI
by GE HealthCare
MRI-compatible anesthesia machine ideal for both the MRI suite and the operating room
The machine’s low profile design features a low height and small footprint, allowing clinicians to easily move the unit from one care setting to another.
-klinikudarbo
Thu Jan 16 2025
Service calibration
An alarm line with "Srvice Calibration" is on. What to do?
Thank you
-Amalkj
Tue Aug 06 2024
How to remove battery
Equipment: GE HealthCare - Aestiva/5 MRI
  • Designed for use in MRI settings up to 300 Gauss, active shielded 1.5T and 3T magnets.
  • Physically integrated magnetic field strength monitor (Gauss alarm).
  • Compact size, small footprint and low overall height takes up minimal space in MRI suites and operating rooms.
  • 7900 SmartVent™ with the following ventilation modes: Volume Mode, Pressure Control Mode, Pressure Support (PSVPro®), Synchronized Intermittent Mandatory Ventilation (SIMV), electronic PEEP.
  • Ventilator features tidal volume compensation and cardiac bypass case mode.
  • Innovative patient breathing system features a responsive location of the common gas outlet.
  • Low flow design features a minimum O2 flow of 50 mL.
