DRE - Ventura CS5
A Safe, Reliable Anesthesia System Built for the Modern OR
The DRE Ventura CS5 is a high-quality anesthesia system with the intuitive controls, modern styling and robust features necessary for today’s operating room. Using the unit’s easily accessible color touchscreen, clinicians can navigate the many settings of the DRE Ventura CS5 Anesthesia System.
The machine’s interface features many default settings that make the setup of the DRE Ventura CS5 quick and easy. Clinicians can also create individual patient settings with custom naming conventions. The fully-integrated anesthesia ventilator is designed for both adult and pediatric use. The DRE Ventura CS5 standard configuration includes three stainless steel drawers, extendable writing tablet, vaporizer and oxygen monitor.
1Reply5 years ago | service manual anyone have a service manual that they can share?Reply |
- High-quality anesthesia workstation with a 10.4” TFT color touchscreen with large, easy-to-read controls
- Fully-integrated, ergonomically positioned ventilator and absorber
- Multifunction anesthesia ventilator designed for adult and pediatric use. Advanced ventilation modes include volume-control and pressure-control
- Up to six ventilation modes: Volume, PCV, Spontaneous, PSV-plus, SIMV and SMMV
- Dual flow tubes with two or three gases and low flow cascade tubes on all gases
- Durable extruded aluminum construction with solid plastic moldings
- Two-hour battery backup in the event of building power failure
- Up to three station Selectatec® compatible backbar with interlock
