Philips - EPIQ CVx
by Philips
Cardiology Ultrasound System
The EPIQ CVx is a dedicated cardiac ultrasound solution which brings significant advancements in functionality. This helps you deliver better care through higher processing power, exceptional imaging with more clarity & sharpness, improved exam efficiencies, and new robust & reproducible AIUS quantification.
4RepliesSat May 16 2026 | X5-1 transducer DiagCode: 005 error I have a Philips X5-1 xMATRIX transducer that stopped being recognized by the system. The ultrasound initially displayed the message "Reconnect the transducer. The current transducer cannot be selected… DiagCode: 005" and subsequently a critical error that forced a system restart with DiagCode: 207.GB9G.FARG.5 (SoftwareBuildVersion 9.0.16.1181). Has anyone had experience with issue and success resolving it. Thanks for any and all responses. Equipment: Philips - EPIQ CVx Reply |
0RepliesThu Jul 31 2025 | Release 10 Need i a new hardware apart of software? Equipment: Philips - EPIQ CVx Reply |
2RepliesFri Dec 20 2024 | Keep getting message " An unauthorized application has attempted to run and the whitelisting function of the system has successfully blocked this action." I have a Epiq CVx that we keep getting message " An unauthorized application has attempted to run and the whitelisting function of the system has successfully blocked this action." Does anyone know what that means? Reply |
| Weight | 104.3 kg |
| Width | 60.6 cm |
