DRE - Bonair
by DRE
An electronic time-cycled ventilator with integrated patient alarms
The Bonair has adjustable inspiratory time, expiratory time and flow rate. Adjustable low and high-pressure alarms are provided.
This Bonair Anesthesia Ventilator can be placed on any flat surface or mounted on a dovetail bracket for use on the side of an anesthesia machine. The low-pressure alarm is the minimum patient circuit pressure that must be achieved with each breath while the high-pressure alarm stops the inspiratory flow when the set high pressure is achieved.
  • Adult Bellows Assembly
  • Pediatric Bellows Assembly
  • Bellows Drive Hose
  • Patient Circuit - Drive Hose
  • Pressure Sensing Hose 2.5m/22mm M/F Connector
  • Anesthesia Machine Dovetail Bracket
  • Patient Circuit Presure Monitor
Height240 in
Length 260 in
Weight8 kg
Width300 in
