Tuttnauer - EZ11 Plus
by Tuttnauer
Fully Automatic Autoclave
The Tuttnauer EZ11Plus is a fully automatic autoclave designed for today's busy medical practice. Sterilize and dry instruments quickly with the autoclave's closed door drying and efficient air pump. The EZ11Plus features a multicolor display to show cycle information and a networking port to monitor the autoclave remotely. Use the unit's many loading options to find the right configuration for your practice.
2Repliesa month ago | Ez11plus Temp problem. High heat error On the POS Autoclave ez11 ,my display for the temperature keeps fluctuating to all different temps.any where from 68 to 160 degrees. If it is run it will get a high temp error. I did switch out the temp probe and same thing, I even unplugged the temp probe and the same situation ??. Tyia Mark Reply |
0Repliesa month ago | Finding calibration procedures from Technical Service Manual Where to find Technical Service Manual?http://www.frankshospitalworkshop.com/equipment/documents/autoclaves/service_manuals/Tuttnauer%20EZPlus-Series%20Autoclave%20-%20Service%20manual.pdf Equipment: Tuttnauer - EZ11 Plus Reply |
7Replies2 months ago | Calibrate Does anybody know step by step way to calibrate an easy 11 plus thank you in advance. Or better off send me a link to a video on how to do it Equipment: Tuttnauer - EZ11 Plus Reply |
