Bovie - Bantam PRO A952
by Bovie
A high frequency desiccator with cutting ability, designed for office-based procedures
The Bovie Bantam PRO A952 is a High-Frequency Desiccator with cutting ability. You might call it a split personality. One half of the unit is a high-frequency desiccator, an upgrade to the Aaron® 940. The other half is a Bovie Generator, giving you 50 watts of cutting power and coag capabilities – plenty of power for most cutting procedure performed in the doctor’s office.
-Chris-CBET
6 years ago
testing procedure
In case anyone is testing one of these and needs the load specs: OUTPUT CHARACTERISTICS Maximum Output for Monopolar and Bipolar Modes Power readouts agree with actual power into rated load to within 20% or 5 watts, whichever is greater. * an indication of a waveform's ability to coagulate bleeders without a cutting effect A-8 Bovie Medical Corporation Mode Output Power Output Frequency Repetition Rate Open Circuit Vpeak max Crest Factor* (@ 800 ©) Cut 50 W @ 500 © 343 kHz ± 10% N / A 1600V 2.2 ± 20% Blend 50 W @ 800 © 368 kHz ± 10% 46 kHz ± 10% 2100V 3.5 ± 20% Coagulation 50 W @ 1000 © 340 kHz ± 10% 49 kHz ± 10% 2900V 5.2 ± 20% Fulguration 40 W @ 1000 © 410 kHz ± 20% 21 kHz ± 10% 6300V 9.5 ± 20% Bipolar 40 W @ 200 © 368 kHz ± 10% 37 kHz ± 10% 950V 5.5 ± 20% Micro Bipolar 40 W @ 50 © 338 kHz ± 10% N / A 300V 2.6 ± 20%Reply
  • Cut Mode - gives a general cutting with a standard RF waveform to cut all types of tissue with minimal hemostasis
  • Bend Mode - a combination of Cutting and Hemostasis (55/45) which offers increased control of bleeding at the surgical application site
  • Coagulation Mode - provides precise control of bleeding in localized areas
  • Fulguration Mode - produces a sparking at the skin surface for more shallow tissue destruction
  • Bipolar Mode - more aggressive coagulation mode, with some arcing, and works with modulation and a crest factor of 4.8
  • Micro Bipolar Mode - more gentle mode of coagulation, has no arcing, and works with continuous waveform and a crest factor of 2.6
Height188
Length 105
Weight2.26 kg
OutPut Frequency451 kHz
Width228
Output Power:
  • Cut: 50 watts
  • Blend: 50 watts
  • Coagulation: 50 watts
  • Fulguration: 40 watts
  • Bipolar: 40 watts
