DRE - ASG-300
by DRE
Essential for the Most Demanding Procedures
The DRE ASG-300 ESU ( offered New or Factory Refurbished ) uses dedicated digital hardware instead of a general purpose controller for processing data. This hardware allows parallel data processing and generates very high data processing throughput, measuring tissue impedance 5000 times per second.
All data is sampled and processed digitally, being converted to analog only in the output stage. This permits reproducible cuts regardless of the tissue type and enables digitally controlled cutting effects for efficient operation and optimal results with a high degree of safety. This innovative cut behavior can be utilized in a variety of procedures, from high-powered/high-impedance procedures to general applications.
This digital technology makes controlling the ASG system very simple for OR teams during any point of any procedure, allowing surgeons to concentrate on what's important — the operation and the patient.
0Replies2 years ago | Troubleshooting help Troubleshooting .my electrosurgical DRE Asg 300 has been doing fine until a few days ago .Can't cut or coagulate on monopolar .my plate is ok ,cutting probe.even if I increase cutting power to 50 Reply |
1Reply3 years ago | Error 4 What is the possible cause of fault E4 with the DRE ASG-300?Reply |
2Replies5 years ago | DRE ASG-300 Electrosurgical Generator SERVICW MANUAL NEED SERVICE MANUAL OR FIND OUT WHAT IS ERROR E4 IS?Reply |
Height | 6 in |
Length | 16.3 in |
Weight | 19 |
Width | 12.3 in |
Power:
