GE HealthCare - Giraffe OmniBed
by GE HealthCare
Full-featured incubator and a radiant warmer.
The GE Giraffe OmniBed combines two traditional infant care products in one. A full-featured incubator and a radiant warmer in one. Protects from heat loss while the bi-directional maintains thermal stability. The infant receives uniform heat regardless of position.
0RepliesThu Apr 23 2026 | Software program Would anyone have the software they would be willing to send me? Or the link to the GE page so i can download it from there? I have an omnibed that is not keeping the time/date even after having new batteries put in Reply |
2RepliesMon Jan 26 2026 | Humidifier Calibration Has anyone ever done the humidifier calibration? I am trying to do them now on the older models, the ones with the orange displays and I cannot get them to pass. It keeps failing the cals. I am following the service manual instructions. 1. Take the cap off the humidity calibration bottle and add one half cap full of sterile distilled water to the bottle. Shake the bottle to thoroughly mix the salt and water solution. Place the smaller end of the elbow over the bottle. 2. Slide the elbow over the humidity sensor (mounted on the back wall) until it stops. This creates a 75% RH environment for the sensor. 3. Hold the override key while powering up to enter the service screen. 4. On the second service screen, select Cal RH. The screen will prompt “Push knob when RH reading is stable.” Wait for 20 minutes or until the RH display stabilizes (does not change by more than 1% in 5 minutes). 5. Depress the control knob to complete the calibration. On software revision 1.3 and higher, you will have the option to select STABLE, SET TO DEFAULT or EXIT. STABLE initiates calibration. SET TO DEFAULT resets calibration values back to factory default settings. If you started calibration by mistake (without the calibration bottle in place, for example) you would select SET TO DEFAULT and then calibrate the unit. If you have entered the calibration routine by mistake, select EXIT to leave without initiating calibration. 6. If “RH Sensor Calibration Completed” is displayed, the calibration is complete. Depress the knob to exit the Cal RH routine. I am not sure what I am doing wrong. Whether I am not filling the water in the cap right or am I supposed to fill the reservoir with water before proceeding, although the service manual doesn't call for it. If anyone has any ideas what I am doing wrong I'd appreciate the assist. Thanks. Equipment: GE Giraffe OmniBed Reply |
3RepliesTue Jan 06 2026 | Oxygen Sensors Does anyone know where the Oxygen Sensors are in the GE OmniBeds? I am using the most up to date service manual to locate them and where it points me to them, that is the fan motor. I know our O2 sensors have never been replaced. Do all the OmniBeds have O2 sensors or do some not have them? Question #2, when I order the calibration kit for the humidifier calibration, would one be enough for the 6 OmniBeds I have or will I need more than one? I would ask GE but of course they would want a PO. I've also never done the Servo cal. Like I said, no one has ever replaced the O2 sensors on these things if they even have them. I have never been able to find them. Thanks Equipment: GE HealthCare - Giraffe OmniBed Reply |
| Height | 58 in - 70 in |
| Length | 26 in |
| Weight | 285 |
| Width | 45 in |
