Oakworks - ProLuxe PT300
A truly multi-functional choice for medical facilities.
With superior positioning capabilities for maximum patient access, a 550 lb. (249 kg) weight capacity enabling Bariatrics service, 17" low height range, enabling ADA tax credits and push-button height adjustability for exceptional accuracy and convenience, you get just what you need to accomplish maximum efficiency and best possible procedural outcomes
- Ultimate Access to Patient's Neck and Upper Torso
- Manually Adjusted Two Break (Three Section Top) - Any position, from flat to seated the three section top is ready to support your clients for a wide variety of treatments and includes an integrated Oakworks Crescent Face Pad that can be reversed to support both prone and supine positioning.
- Top-Rated Motor - The super-quiet motor has a 550 lb. lifting capacity. Reliable plug and play electronics guarantee secure operation.
- Professionally Engineered Construction - The only X-Brace table that offers stability and strength at every height range and with even your largest bariatric clients. Exceptional height range helps you achieve compliance for up to a 50% ADA tax credit.
- Foot Controls - Improve efficiency with the added convenience of two foot controls. A single foot control is included with the table and an additional control can be added.
- Wheels - Automatically locked when in working position, these wheels allow smooth easy lift operation.
Height | 17 in - 34.5 in |
Length | 73 in |
Weight | 275 lbs |
Patient Weight Capacity | 550 lbs |
Width | 27 in |
