GE HealthCare - Marquette TRAM 451N
by GE HealthCare
OR Oxismart module
The TRAM multi-parameter module allows patient data to move with the patient throughout the hospital. This allows critical data to remain with the patient so you can access complete information at the bedside when you check on patients after surgery.
TRAM captures information from other modules connected to Solar monitors, including ETCO2 and gas information. It also acquires data from external devices connected via the Unity Network ID, such as ventilators to provide a complete patient record.
2RepliesFri Aug 20 2021 | Adapter cable Hi I need to know if the Marquette 451n with Nellcor Oxismart can be used with the Nellcor Oximax spo2 finger probes by using an adapter cable. And if so what is the part number please. We accidentally purchased some 451n trams thinking they were oximax units but instead were the oxismart . All help will be greatly appreciated. Thanks Reply |
2RepliesThu Jul 23 2020 | TRAM 451N with corrupt software Has anyone EVER had a problem with a TRAM module becoming corrupt and not allowing you to admit or discharge? When you choose the ADMIT button it re-boots! And then, if you replace the TRAM with a known good one, it becomes corrupt as well. HELP!Reply |
