Welch Allyn - Connex 6000 Series
An advanced, touch screen monitor measuring continuous SpO2, temperature and blood pressure parameters
This monitor is an intuitive, touchscreen monitor featuring bright, vivid colors for improved workflows and training. Adaptable for most low-acuity healthcare environments and clinical workflows, it can measure pulse oximetry, non-invasive blood pressure, temperature, EtCo2, respiration and more. Multiple profiles support spot check vitals, averaging, intervals and continuous monitoring workflows. Help prevent patient deterioration using optional early warning scores. With wireless EMR connectivity, the CVSM sends vital information where your clinicians need it, when they need it.
1Reply10 months ago | Welch Allyn 6000 Series I would like to know if anybody know the password for welch allyn 6000 Series. Reply |
0Replies2 years ago | Top corners of touchscreen not responding. The whole touchscreen works and is calibrated except for the upper two corners of the screen where you can press to silence an alarm and where you would press "OK" to clear a notification. I've tried cleaning the screen with a 70% alcohol wipe and I've also tried calibrating the screen, but it always comes back saying "touchscreen calibration has been confirmed". Does the touchscreen need to be replaced or is there a simpler fix for this issue? Reply |
- SureBP® supports all ages and provides 15-second readings as the cuff inflates
- SureTemp® Plus and/or Braun ThermoScan® PRO 6000 Ear Thermometry
- Masimo® or Nellcor® Pulse Oximetry (SpO2) Algorithms
- Health o meter®, Seca and Detecto weight scale connectivity
- Wireless connectivity to leading electronic medical records
- Ships standard with one adult and one large adult cuff
