GE HealthCare - LOGIQ P6
by GE HealthCare
High-end and easy-to-use multipurpose portable color Doppler system.
With advanced detail resolution and color flow, users can easily distinguish between cystic and solid lesions, especially in small areas like the thyroid, breast and ovary. And the increased detail and contrast resolution help identify even the most challenging pathologies. These capabilities help to optimize user's ability for earlier diagnosis. Whether it’s visualizing vessels that havemultiple velocities or minute vessels in the kidney, LOGIQ P6 makes it easy for users to scan patients from the NICU to geriatrics. And with raw data capability, users can do their postprocessing analysis later, minimizing user interaction time with fragile patients.  Finally, there’s an ultrasound system that empowers users with certainty wherever they need to go and no matter who they need to scan.
FORUMSView All (12)
-RC18
Fri Oct 03 2025
artifact
Intermittent artifact regardless of what probe
Equipment: Logiq P6
-Hugo Farias Lima
Sat Aug 17 2024
Password
Heey Friends, does anyone have the GE Logic P6 pro ultrasound administrator password? I tried arirang and couldn't!
Equipment: Logic P6 pro GE
-ussono
Wed Aug 08 2018
dgc do not work and the image is bright
Does anyone have theservice manual for theLogiq P6Reply
More Applications
  • Its combination of performance and versatility enables users to meet the needs of patients across multiple clinical settings. Achieve confidence across more applications.
Service & Support
  • GE knows users need more than just confidence in the equipment they use
Portability
  • LOGIQ P6 was designed with users in mind as you travel from room to room and floor to floor, scanning bedside and sometimes in challenging spaces
Clinical Images
  • It’s simple. A clear image leads to the most confident decision
Cart Based1
Height1360 mm
Length 640 mm
Weight176 lbs
Clinical ApplicationsColorectal
Imaging Capabilities2D/3D
Doppler Modes3-D, Color, Continuous wave (CW), Pulsed wave (PW)
Image Display17 in Color Flat Panel
Width430 mm
NEWSView All
Trisonics- Authorized Distributor For GE Healthcare
