Skytron - SkyVac Smoke Evacuation System
by Skytron
The built-in SkyVac System captures microorganisms and particulate matter at the rate of 99.9995% efficiency @ 0.1 microns,using Front-Endfiltration design. Filtration is done prior to entering the boom or permanent lines,eliminating the need to decontaminate any part of the system.
  • Normal or Turbo Speed Suction provides up to 32 cfm at surgical site
  • “Front-End” Filtration, Low Maintenance Design
  • Optional Automatic Surgeon ON/OFF Control with Auto Sensor
  • Front load filter change is a speedy, one-step process without tools or help from biomed
  • SkyVac universally accepts a wide range of laparoscopic smoke evacuator tubing sets, including 1/4” (6mm), 3/8” (10mm), 7/8” (22mm), 1” (25.4mm) and 1-1/4” (32mm) sizes.
  • Dimensions: 7 ½”H x 16 ¾” W x 20”D
  • Built into equipment carrier, thereby freeing up shelf and floor space
  • Touch pad control and LCD display allows for simple operation
  • Features quiet performance
  • Eight-hour multi-port filter promotes efficiency
  • Optional Remote Switch Activator or Pneumatic Foot Switch available
  • Designed for use with Skytron KM or PM equipment carriers
