Sun Medical - SFE-200
by Sun Medical
Smoke Evacuation System
THE NEW STANDARD The SFE-200 sets a new standard for smoke evacuation during a laparoscopic? procedure. Providing a clear field of vision by capturing particles as small as .02 microns with a 99.999% efficiency rating, the SFE-200 re-circulates and filters the pneumoperitoneum at a maximum flow rate of 16 Liters/Minute. Once the patient has been insufflated, no additional CO2 is needed when evacuating smoke or fluid. Valuable OR time need not be wasted due to loss of pneumoperitoneum.
  • Sophisticated Design
  • LED digital display
  • Rotary vein pump (flow rate from 13 Liters/Minute during normal smoke evacuation to 16 Liters/Minute during high flow fluid suction)
  • Real time intra-abdominal pressure monitor
  • Photo sensors to protect the SFE-200 from fluid contamination
  • Automatic alarm reset
  • Model SFE-200 (91-200-00)
  • Power Requirement 110i20vAC,60Hz
  • Height 7.23 in. (18.29 cm) width . tiin. (27.83cm)
  • Depth 14.5 in (36.68 cm) weight 12.5lb.(5.63kg)
  • Flow: 16 Liters/Minute
  • Smoke Evacuator Circuit (87-30o-oo)
  • Sterile Disposable Suction Canister (Non-Sterile) 1.200 cc Length 343.8cm(96in.)
  • Fluid Suction Canister (87-400-0o)
  • Non-Sterile Safety Float Shut-Off Capacity 1,im0ccy
