Siemens - Cios Select
by Siemens
Mobile C-Arm
Downtimes and unpredictable service incidents can have a negative impact on the total cost of ownership, which may lead to precarious financial situations.
With Cios Select, users can safeguard the financial sustainability of their clinical institution with smart surgical imaging and service from a single reliable partner. Benefit from high system availability, low maintenance and reduced training requirements, and a global service network.
FORUMSView All (15)
-Medical Tech
Fri Dec 19 2025
error 5211/80 and error 10
Hello, just took an exposure on Siemens Cios Select and saw an error on the monitor: ERR 5211/80 and on the C-arm: ERR 10. The image of the exposure is grainy. How to diagnose and remedy this?
Equipment: Siemens - Cios Select
-Fiks
Mon Sep 08 2025
Workstation failing to boot properly
When switched on the workstation for the c arm fails to boot properly.at times after restating the machine both the workstation and generator it works but in  most cases it doesn't start( workstation) the UPS is fine and working okay.
-StephD
Sat Aug 24 2024
Err 10 code
I'm getting an error code on a Siemens Cios Select. It’s still taking images, but after each image, it is showing “err 10” on the base of the c-arm where it normally displays the angle and p/s. Any ideas?
  • Based on long-term experience in surgical imaging – successor in a long line of well-known, established mobile C-arms
  • Robust hardware and software – thoroughly tested and proven
  • Tailored service offering – for you and your mobile C-arm machine
  • Simple button-based system control – via the robust control panel on the main unit and monitor cart
  • Intuitive C-arm positioning – with color-coded axes and brake handles
  • Easy to maneuver and position – thanks to the compact, lightweight design of C-arm and monitor cart
  • Ideal for routine cases – in ortho and trauma surgery as well as urologic and basic vascular procedures
  • Sharp images at high resolution and low dose – thanks to advanced CCD camera and optics combined with IDEAL dose management
  • Radiation-free, precise C-arm positioning – with integrated laser light localizer on image intensifier
Dimensions: 179.5 cm x 80 cm x 173.5 cm
Weight: 275 kg
Field of View: 23 cm
