Smoke Evacuation System
The OptiMumm" smoke evacuator is the centerpiece of a complete smoke evacuation system when used with the AccuVac" smoke evacuation attachment, Valleylab's universal mounting system, and either the Force FX" electrosurgical generator or the Force EZ" electrosurgical generator.
- Quiet- The OptiMumm™ system allows you to effectively filter and remove surgical smoke without creating additional noise in the OR.
- RapidVac™ System- Synchronize the OptiMumm™ smoke evacuator with your electrosurgical generator, so the smoke evacuator will work automatically when the generator is activated.
- Efficient-The OptiMumm™ smoke evacuator is designed specifically for use with the AccuVac™ smoke evacuation attachment to effectively capture and filter smoke directly at the surgical site.
- Convenient-The OptiMumm™ system is designed with an easy to read front panel and a user-friendly interface. The ULPA and prefilter are easy to access and set up.
- Compact-The OptiMumm™ smoke evacuator integrates conveniently into the OR. The system fits directly on most Valleylab mounting carts, saving valuable OR space.
- User-Friendly- The filter life indicator is based on airflow, not just time, so you know when to replace the ULPA filter.
- Dimensions: 93/4 in. (9 in. without feet) H x 13 %8 in. w x 13’/2 in.
- Weight: 35 lbs
filters: ULPA: 99.999% efficient at 0.12 microns
integrated charcoal component with CTC rating of 62
prefilter: rated for 0.3 micron filtration
- Electrical: voltage operating range: 100—120 VAC, 60 Hz: current: 6.0 amps, maximum
- Compatible Carts: Universal mounting cart system — main, upper, or lower shelf
E8006 mounting cart — middle shelf
E80o8 mounting cart - middle shelf
- Certifications: UL, CE, cUL, ASA, TCJV
