Philips - Hearstart XL+
by Philips
Defibrillator
Cardiac emergencies are usually stressful, chaotic events, and the last thing you need to worry about is if your defibrillator is ready for use. The Philips Heartstart XL+ Defibrillator/Monitor has been designed for Resuscitation and Rapid Response teams. It features meaningful innovations that will help you effectively and confidently respond to patients and situations throughout the hospital.
The Heartstart XL+ uses a similar interface, alarms, as well as identical cables and accessories as the MRx and other Philips monitors. Because it is built on a scalable platform you can customize your XL+ with the functions that best meet the needs of your staff, from BLS responders to ALS clinicians.
-Mrtnrgz
Thu Mar 09 2023
Equipment disabled therapy
The device works, but it gives equipment disabled therapy failure. In my research, I came to the conclusion that there may not be a serial number, but the serial number is written in the device information. can you help me solve this error?Reply
  • Manual and AED operation
  • Multifunction Therapy Cable
  • 3-Lead ECG monitoring with included monitoring pads or electrodes
  • Integrated AC Power
  • Lithium-ion Battery
  • Test Plug
  • CD with Application Notes, Learning Products, Instructions for Use
  • One Roll of Printer Paper
  • SMART Biphasic waveform for defibrillation
Height9 in
Length 10.9 in
Weight14.7
Defibrillator TypeExternal, Manual
Width11.6 in
