Thermo Fisher Scientific - MaxQ 5000
Incubator
Complete large capacity applications with ease using the Thermo Scientific™ MaxQ™ 5000 Floor-Model Shakers, make cleaning spills easy and retractable foot casters to easily position the shaker in the lab. These shakers also feature a foot pedal for hands-free operation and a large slanted viewing window to check progress. Ideal for cell culture, solubility studies, plasmid purification, staining and destaining, extraction procedures, protein expression, and many other applications.
2Replies9 months ago | "Not Shaking" Hi, I am looking for tips or advice on reinstalling the belt and platform for the SHKE2000. I fixed a component on the board. I reinstalled the belt, aligned the platform, and installed it according to the manufacturer. However, it will not rotate/shake with the belt installed. It will rotate and shake, manually by hand, when the belt is off. But not when the belt is reinstalled and/or with platform in place. Any help or knowledge on this matter? Thanks, Brian Equipment: Thermo Fisher MaxQ 2000 SHKE2000 Reply |
- Easily accommodate six 4L flasks, four 6L flasks or six 2800mL Fernbach flasks
- Wide temperature range: 10°C above ambient to 60°C on incubated models, 15°C below ambient to 60°C on refrigerated models
- Monitor and control chamber temperature range with ±0.1°C accuracy at 37°C
- Overtemperature safety feature with independent thermostat provides additional backup by controlling heat if main temperature controller fails
- Triple eccentric drive handles heavy loads, uniform agitation and continuous 24 hr. operation, even at high speeds
- Drip pan built into the chamber floor under the platform contains spills
- Clear, scratch-resistant lid for sample viewing
- With foot pedal for hands-free operation and retractable casters for portability
- Access ports provided through the side of cabinet wall for probes, thermocouples or sensors
Height | 41 in |
Length | 32 in |
Width | 41 in |
- Temperature Range: -15 to 60°C
- Capacity: +/- 0.1°C at 37°C in flask
- Speed: 15 to 500 rpm
