IMT Analytics - SmartLung 2000 2L
by IMT Analytics
Analyser Measurement & Simulator
With the new SmartLung 2000, you can test ventilator compliance with the following standards: IEC 60601-2-12,IEC 60601-2-13 and EN 794-3. The SmartLung 2000 is the best tool for testing your ventilator and anesthesia devices and an ideal addition to our flow- and pressure measurement devices, FlowAnalyser and CITREX. By simply moving the slider, the test lung can simulate different degrees of lung stiffness and a simple twist of the connector is all it takes to simulate different airway resistances.
-Alexandria
Thu Apr 25 2019
IMT Analytics test lungs
IMT Analytics test lungs are a simple and cost-efficient solution to safely verify ventilators and anesthetic devices for functionality and precision.Reply
-Alexandria
Thu Apr 25 2019
IMT Analytics at MD EXPO Houston 2019
Live broadcast with IMT Analytics and MedWrench at the MD Expo Houston discussing their test lungs. Learn more at www.imtanalytics.comReply
VIDEOS
IMT Analytics test lungs...
IMT Analytics at MD EXPO Houst...
  • 2000-ml-bag
  • Applicable volume from 0 to 1000 mL
  • Testing according to IEC standards (ventilators and anesthesia machines)
  • The only test lung on the market that covers all the necessary test points
  • Outstanding features for patient simulations in ventilator training
Height40 mm
Length 400 mm
Weight400 g
Leakage : Adjustable
Resistance : 5, 20, 50, 200 mbar/L/S
