IMT Analytics - SmartLung Adult 1L
by IMT Analytics
Analyser Measurement & Simulator
SmartLung offers the same performance as large, expensive test lungs. It is extremely simple to use and so compact that it can be connected directly to the ventilator tubing system. The SmartLung is unbeatable in terms of price/performance ratio. Resistance (airway resistance), lung compliance and leakage are all adjustable.
Its size eliminates the cumbersome side-tables needed by large test lungs. Different bag sizes ensure that virtually all patient lungs can be simulated; from babies to adults. The SmartLung does not require any additional adapters.
The Leakage is infinitely variable and enables verification of premature infant ventilators as well as mask ventilation. Even the sensitive function of the patient flow triggering can be tested with the SmartLung.
0RepliesThu Apr 25 2019 | IMT Analytics test lungs IMT Analytics test lungs are a simple and cost-efficient solution to safely verify ventilators and anesthetic devices for functionality and precision.Reply |
0RepliesThu Apr 25 2019 | IMT Analytics at MD EXPO Houston 2019 Live broadcast with IMT Analytics and MedWrench at the MD Expo Houston discussing their test lungs. Learn more at www.imtanalytics.comReply |
| Height | 40 mm |
| Length | 300 mm |
| Weight | 325 g |
