Sorvall - RT6000B
Combines the features of the tabletop centrifuge and a larger refrigerated centrifuge in a compact tabletop instrument.
The RT6000 is similar to other SORVALL® Tabletop Centrifuges, with an added refrigeration system that consists of an evaporator/rotor chamber and a low-temperature condensing unit. The system is designed to maintain the temperature within 1°C, while in the operating range of –5°C to +25°C.
3Replies5 years ago | Lid Latching Issues The lid on my centrifuge is not locking when i close it to start using it. Even after locking the latch it will not close for some reason. Are there any trouble shooting procedures i can do for this? Thanks, Reply |
- Suitable for all lower speed large tube number applications such as spinning 15ml and 50ml conical tubes
- See-through chamber door that allows rotor calibration and visual inspection of a run in progress
- The lid latch is locked manually by turning the door release knob counterclockwise then spinning preventing the chamber lid from being opened during operation
- Slow-start feature allows slow smooth acceleration from 0 to 500 rpm.
- High torque motor
