Ortho Clinical Diagnostics - ORTHO Workstation
Precision and accuracy are critical in labs of any size
The ORTHO™ Workstation is the only compact 2-in-1 blood testing system with reliable ID-Micro Typing System™ (ID-MTS™) Gel Column Agglutination Technology (CAT). It’s a system engineered to help ensure the accuracy your patients deserve—with the convenience and ease of use your lab needs.
0Replies4 years ago | How to teach the centrifuge How do you Tach the centrifuge, it looks like it has a solid cover. Have not seen this model in any lab as of now.Reply |
1Reply5 years ago | Service Manual Hi there, Does anyone have the Service Manual for the Ortho Workstation?Reply |
- Increase accuracy - provide the accuracy your patients deserve with a validated system of ID-MTS™ Gel Cards—the serological standard for blood banks—with centrifuge and incubator
- Maximize space - maximize space in your lab with this compact 2-in-1 system that integrates the ID-MTS™ Gel Cards, centrifuge, and an incubator
- Simplify operations - language-neutral icons, enhanced alarm systems, easy-to-perform centrifuge QC using a tachometer, and quick access to holding area for centrifuge balance-card
- Improve process controls - more control over processing with incubator temperature monitoring with a visual indicator, a unique beeping pattern to indicate cycle completion, enhanced error code intelligence for troubleshooting, and a quiet centrifuge with translucent panels for visual monitoring
- Reduce your lab's footprint - a system designed with the environment in mind
