InMode - Fractora
by InMode
The ultimate non-invasive skin renovation without surgery
Fractora is a fractional skin resurfacing and subdermal tissue coagulation device that bridges the gap between fractional lasers and surgical procedures. Clinical papers demonstrate outcomes such as improvement in skin complexion, reduction in skin irregularities and restoring skin to a more youthful appearance. This all occurs within one session or multiple sessions, depending on patient preference. Fractora can be used on active cystic acne and acne scars.
-Ray W
5 years ago
Fractora Handpiece connector wiring sequnce
Does anyone know which colour wire goes on which pins for the Fractora Handpiece. The 4 wires (Black, Red, White, Green) broke off the connector to the machine and I just need to solder them back on in the correct sequence. It is easy to slide back the cover over the wiring to view if you have a handpiece available. Thank-you in advance! Reply
  • Addresses multiple problems, including treatment of wrinkles with fractional coagulation and ablation
  • Significant resolution of cystic acne and scars (improving acne scarring by 50%)
  • Safe on skin type VI with little risk of post-inflammatory hyperpigmentation (PIH) which is common with other resurfacing methods
  • Combination of fractional coagulation and volumetric heating through tips with various depths and pin density configuration
