Datex Ohmeda - D-TEC Plus
by Datex Ohmeda
An ideal choice for facilities requiring a reliable, electronic, desflurane anesthesia vaporizer
The Datex Ohmeda D-TEC Plus has an onboard LED screen to indicate no output, low agent, battery low, and warm-up, the Tec 6 Plus delivers constant, carefully-monitored amounts of desflurane with your patient.
The Tec 6 Plus also features self-diagnostic protocols to check the machine every time it is turned on. It has a sump capacity of 425 mL, allowing clinicians to use the vaporizer for extended periods between refills. The vaporizer can be refilled during use.
  • Various safety features make providing desflurane anesthesia safe and effective.
  • Completes self-diagnostic exams each time the vaporizer is turned on.
  • Sump capacity up to 425 mL, nearly 2 bottles of Desflurane, for extended use between refills.
  • Onboard LED display indicates: no output, low agent, battery low, warm-up.
  • Refilling can be done while the vaporizer is in use.
  • Unique Saf-T-Fill valve designed to fit the complementary Tec 6 Plus filling device, helping to prevent accidental release of vapors.
Height9.84 in
Length 9.25 in
Weight21 lbs
Width4.33 in
