Datex Ohmeda - Tec 5 Sevoflurane
Designed for out of circuit use in continuous flow techniques of inhalation anesthesia
The GE Datex Ohmeda TEC 5 Sevoflurane anesthesia vaporizers are temperature, flow, and pressure compensated so that its output remains relatively constant despite cooling due to evaporation. The TEC 5 is designed to be used on Selectatec Series Mounted Manifolds.
1Reply4 years ago | Liquid Leak When I, put liquid sevorane, en 1 hour is empty. Thanks Reply |
Height | 25 cm |
Length | 6.4 cm |
Weight | 7 kg |
Width | 11 cm |
Liquid Capacity (Dry wick): 300 Milliliters
Liquid Retained by Wick: 75 Milliliters
