Northgate Technologies - 7645 HUMI High Flow
by Northgate Technologies
A unique feature of the Model 7645 HUMI+ is that it does not require the use of a non-standard tubing set and trocar sizes to implement flow rates above 20 LPM. NORTHGATE® insufflation tubing and standard size trocars can be used.
CO2 Insufflation for all laparoscopic surgical procedures [*] High performance, HIGH FLOW (Up to 40 LPM through either port) [*] Auto Pressure Relief [*] The TAP™ Tubing Sets; a proprietary, independent method for directly measuring abdominal pressure. The benefits are faster, initial insufflation and faster recovery from sudden pressure leaks. [*] Integrates with video tower system and adjusts to low & high pressure CO2 source.
