Draeger - Vapor 19.3 Isoflurane
Used for accurately-controlled enrichment of fresh gas with the vapor of Isoflurane
The Drager Vapor 19.3 Isoflurane anesthesia vaporizer inserts the vapor into the fresh gas line leading to the breathing system of an inhalation anesthesia machine. The Drager-Vapor 19.3 can be supplied with either a key-indexed filling system or with a filling spout.
1Reply3 years ago | Fuite du liquide anesthésique lors du remplissage Au cours du remplissage de mon vaporisateur, je constate une fuite au niveau du module de raccord du BEC VERSEUR. Que faire? Quelqu'un pourrait-il m'aider? Reply |
Height | 21.7 cm |
Length | 14.3 cm |
Weight | 6.5 kg |
Width | 11.6 cm |
Liquid Capacity (Dry Wick): ~200 mL
Fresh Gas Flow Range: 250 mL/min to 15 L/min
Pressure Range: -100 mbar to 200 mbar
