Draeger - Vapor 2000
An unheated, calibrated anesthesia vaporizer
The Drager Vapor 2000 is used for the enrichment of dry, fresh medical gas in anesthesia delivery systems with accurately-controlled concentrations of Halothane vapor. The Vapor 2000 is connected between the fresh-gas flow-control unit and the fresh-gas outlet.
- Economy meets ergonomics - easily refill a Vapor and have it back in service quickly without having to worry about where to store the remainder of the anesthetic you are using
- Safe and simple transport - can withstand tipping or even being turned upside down without any ill effects
- Highly compatible - designed to work with practically any Dräger anesthesia workstation
- Operational within a wider temperature range - can be safely operated at temperatures ranging from 10 – 40 °C making them particularly suitable for use in operating rooms where cooling or heating is an essential factor
- Made with patient safety in mind - the color of each vaporizer corresponds to the color code of the anesthetic agent for which it was designed
- Zero calibration - the Vapor line of vaporizers requires absolutely no calibration, saving you time
- Backup power - electrically driven and comes equipped with a battery which maintains function in case of a power failure
Height | 24.6 cm |
Length | 18.8 cm |
Weight | 8.8 kg |
Width | 10.8 cm |
Liquid Capacity (Dry Wick): ~360 mL
Liquid Capacity (Moist Wick): ~360 mL
Flow Range: 0.25 to 15 L/min
