Ziehm Imaging - Exposcop 7000
by Ziehm Imaging
Mobile C-Arm
The Ziehm 7000 C-Arm is perfect for Chiros that are converting to pain management. The system is the first Ziehm C-Arm model to use the CCD Camera and is an upgrade from the CB7-D.
FORUMSView All (6)
-Ayrton
Thu Jan 08 2026
Error 28
An oil change was performed because initially errors 26 and 29 appeared, which mention something about the generator overheating or a malfunction. Upon inspection, an oil leak was found, which was the likely cause of the overheating. After changing the oil and gaskets, the generator started again, but now error 28 is appearing. The technical manual available online provides absolutely no information about this error. Has anyone else experienced this?
-drmad
Fri May 30 2025
Oil leak
The x-ray tube is leaking oil. How do I troubleshoot it?
Equipment: Ziehm Imaging - Exposcop 7000
-Muhammad Najam
Wed Aug 16 2023
E65 error
Hi, I have a Ziehm Exposcop 7000 C-Arm and it isn’t working and it it showing an error on C-Arm stand control panel which is shown in the attached video. Can you please help me out in resolving this issue. Is there any chance that you can check the C-Arm remotely. If not, is there any solution for it. Please help me out.Reply
  • High frequency x-ray generator 20,000 Hz
  • 9/6" dual field image intensifier
  • Body region and application specific keys - Extremities, Chest, Head, Spine, Hip, Metal, Soft tissue, 1/2 dose
  • 17” Monitor (anti-glare) 120 Hz
  • 5” Slave Control Monitor on back of TV monitor (for technician)
