Nellcor - NPB 70
by Nellcor
Pulse Oximeter
The NPB-70 handheld capnograph delivers accurate etCO2 values. The NPB-70 unites end-tidal CO2 monitoring - including waveform display - with proven Nellcor Puritan Bennett pulse oximetry in a portable, handheld monitor. It gives you the sophistication of a bedside monitor and the convenience of a handheld.
SERVICE COMPANIESView All Pulse Oximeter Companies
  • For mechanically ventilated and spontaneously breathing patients.
  • Full-featured capnography previously available only in much larger monitors.
  • For use on intubated and non-intubated patients.
  • The low sample flow rate of 50 mil/min allows monitoring of the widest range of patients, from neonates to adults.
  • Patented Microstream™ technology and versatile range of FilterLine accessories enable CO2 monitoring even in challenging high-humidity environments.
  • Innovative optical bench enhances stable, accurate measurements from a small sample.
  • Capnographic waveforms and trends.
Height2.95 in
Length 5.04 in
Weight3.07 lbs
Width9.06 in
