MSE - Centaur 2
by MSE
Rugged, no-nonsense versatile bench top centrifuge
The Centaur 2 can take a wide range of accessories and is ideally suited for use in clinical, educational and industrial environments. Speed setting and reading with the Centaur 2 could not be easier. Simply set the timer, adjust the speed and that’s all there is to it. Once the speed has been set, it can been left in the same position for repeated runs. A wide removable bowl facilitates both easy access and cleaning.
In common with all other MSE centrifuges, the commitment to safety has been paramount. The Centaur 2 comes with a 5mm thick steel guard ring, a four point burst proof lid fixing, a lid interlock which prevents access to the moving rotor and an out of balance detector which will bring the rotor to rest in the event of a gross imbalance being detected.
Height13.2 in
Length 19.2 in
OrientationBenchtop
Weight79.4
Maximum Speed3600 rpm
Width17.2 in
