GE HealthCare - Vivid IQ
by GE HealthCare
Portable. Powerful. In Touch.
GE Healthcare’s compact directly addresses your changing needs with a combination of portability and power that fits right in – wherever your journey takes you.
FORUMSView All (4)
-Raughbert
Mon Nov 11 2024
Bios battery CR2032?
Is CR2032 the correct battery?
Equipment: GE HealthCare - Vivid IQ
-Ms12345
Mon Apr 22 2024
Local archive error
I have an issue with my local HD archive.
After disconnecting external disk I can't see any patients.
The chosen dataflow is "no archive"
When I try to change it back to local HD archive I get an error: "error. Not connected. Closed"
When I try to check my local archive in connectivity I get a red dot next to it after a test "0 of 1 ok"
I can't access a lot of data because of it. But the files were not deleted because the HD seems to suggest there is not a lot of free space.
Is there any way I can fix it by myself?
-Walter49
Sun Sep 24 2023
System date and time
On booting the machine issues error:check time and date, I hit F1 and have to manually set the current date and time, because the system reverts to 01/01/2004.
I thought it was the clock battery and I have replaced that, but it didn't fix the issue. I have also tried to set date and time from BIOS, but again on rebooting after 10 minutes it reverts again to 2004.
Equipment: GE HealthCare - Vivid i
  • Portable: 10% lighter, 10% thinner than Vivid q
  • Reliable: Rugged, cleanable design built for tough conditions
  • Easy to use: Intuitive touchscreen and fewer keystrokes
  • Convenient: New cart for better management of accessories
  • Advanced: 4D TEE, ICE 3 and other powerful capabilities
