GE HealthCare - Vivid IQ 4D
A combination of portability and power that fits right in with your needs
The Vivid IQ 4D combines the best of the Vivid systems with the portability of a laptop, and while it may be a lightweight at less than 10lbs. - don’t let that fool you - it packs a heavyweight punch. With an intuitive touch interface that uses the same gestures you use on your smartphone, 4 transducer ports, up to 4 hours of battery life with the optional cart, and all the cardiac and shared service quantitative tools you’ve come to love on your current Vivid Ultrasounds, the Vivid IQ 4D will provide you top notch diagnostic imaging for years to come.
The enclosed, flat keyboard surface allows for simple clean up of spills and during routine cleaning - simply wipe down with a disinfectant solution and go about your day. The intuitive trackpad replaces the clunky trackball in the previous models and allows you to switch seamlessly between touchscreen and trackpad. With 4 transducer ports - 3 standard RS and 1 DLP port, your workflow has never been easier.
1Replya year ago | System Voltage Fault this message comes after booting the machine and starting the scanning mode, after 2 mins the message appears "system voltage fault " , I took out the battery and connected the device directly to the electricity, but the same problem occurs Any advice ?! Equipment: GE Vivid Iq veterinary Reply |
- Portable: 10% lighter, 10% thinner than Vivid q
- Reliable: Rugged, cleanable design built for tough conditions
- Easy to use: Intuitive touchscreen and fewer keystrokes
- Convenient: New cart for better management of accessories
- Advanced: 4D TEE, ICE 3 and other powerful capabilities
Height | 64 |
Length | 362 mm |
Weight | 5.2 kg |
Width | 390 mm |
