Faxitron - MX-20
For a broad range of imaging needs under 35kV.
The MX-20 cabinet X-ray is a high throughput planar X-ray system that allows researchers to monitor animals quickly and affordably. This digital system can scan two to three animals at a time depending on size and the scans typically take 12-15 seconds.
KV and exposure time settings can be easily changed by using the computer display or push buttons on the front of the unit. The MX-20 has up to 5X geometric magnification capabilities to deliver ultra-high resolution images of small animals and specimens. The MX-20 model has an energy range of 10-35KV and a tube current of 300uA.
The focal spot size is <20um and the X-ray beam angle is 40 degrees. The resolution of the system is up to 50 lp/mm (10 lp/mm contact mode).
SERVICE COMPANIESView All Mobile Radiography Companies
- No additional x-ray shielding required
- No specialized x-ray knowledge needed to operate
- Plugs into any standard A/C outlet
- Single click calibration for simple, error-free calibration
- No re-calibration or restarting required after transport
- Stainless steel inner chamber designed for easy cleaning and disinfection
- Laser centering guide ensures proper sample positioning
