Taylor - 20-12
by Taylor
The Taylor 20-12 surgical slush freezer is specifically designed for the medical profession to make soft frozen saline or other preferred solution for regional hypothermia for surgical or emergency procedures, and transportation of organs. The Taylor 20-12 is a self-contained freezer is and is, portable, easy to operate, and offers a continuous product of soft formable ice.
No additional support equipment is required. The stainless steel basin meets standard hospital specifications. To operate, pour heat transfer solution, with a freezing point below -35º F (-37º C), in the outer basin. Add the desired amount of sterile solution to the inner basin and press the control switch On. When slush begins to form, simply scrape and stir the solution. As slush is used, just replace with an equal volume of sterile solution to continue freezing.
  • Stainless steel basin.
  • 6-liter volume of the inner basin.
  • One-touch control to start refrigeration.
  • Easily movable with standard casters and hand grips. Two casters have locking devices to help keep the unit in place.
Height914 mm
Length 413 mm
Weight62.1 kg
Width448 mm
