Nihon Kohden - Celltac Alpha MEK-6500K
by Nihon Kohden
Outstanding features. Real benefits.
The Celltac α series provides 3-part-diff and RDW-SD to assist in the detection of iron deficiency or thalassemia.
FORUMSView All (5)
-trimken
a year ago
Have a trouble with MEK-6500K (leaking)
Hello everyone, have a trouble with our Mek-6500K. I don’t know how to correctly describe the technical process and indicate the names of the parts of the analyzer on English, I’ll just attach a video for clarity: https://disk.yandex.ru/i/XdeN8_YhbyyVvg It doesn't give any errors, it just leaks. Equipment: Nihon Kohden - Celltac Alpha MEK-6500KReply
-trimken
a year ago
-aymen guenez
2 years ago
Celltac Alpha communication protocol
Hi, I'm making a software that communicate with Celltac Alpha to get the results. I've searched online and in the manuals and found nothing. Can anyone help please?Reply
Built-in open and closed tube mode
To reduce the risk of contamination, the Celltac α MEK-6500K includes both, an open and a closed tube mode for easy blood sampling.
Auto dilution mode change
You can set panic value thresholds (abnormal high and low values) to trigger re-measurement in preset dilution ratio modes (low, normal, high, higher). In higher mode the measuring range for WBC can be extended to 599 x 10³/μl while the low dilution mode gives high accuracy even in low values of WBC or PLT.
Capillary mode
The Celltac α MEK-6500K allows you to analyze capillary blood with only 10 μl. This is the ideal method to perform CBCs inclusive 3-part-diff for pediatric and geriatric patients.
Unlimited patient memory
The instrument can store unlimited patient samples together with QC results and alarm logs by using SD-card memory (2GB can store 30 000 patient samples).
