Quantum - QV-800
by Quantum
Digital Universal System
Quantum Medical Imaging, designed the QV-800 Digital Universal System, a world-class direct imaging system, for use in all general radiology applications.
The QV-800 incorporates many advanced operational and ergonomic features, with virtually unlimited positioning. The QV-800 Radiographic Projections and anatomical design inherently maintains constant alignment between the x-ray tube and image receptor, regardless of C-Arm rotation or image receptor tilt. Its extraordinary flexibility makes the system ideal for all patients, including those who are physically restricted.
With a focus on today's technology, all Quantum systems provide a path for conversion from analog imaging to Quantum's digital imaging platform.
The QV-800 is a single detector
system that provides film-less
radiography while offering
exceptional system positioning
capabilities. Using a highly
sensitive digital detector, the
QV-800 provides excellent
detailed radiographic images for
optimized diagnostic capabilities.
0Replies4 days ago | Service manuals I am looking for service manuals for this system. Thank you Reply |
2Repliesa year ago | Quantum xray What is the part number for a control board in a Qv800Reply |
The exceptional versatility of the QV-800 permits virtually unlimited positioning. Vertical travel of the C-Arm is dual-speed motorized and easily allows for weight bearing exams on children (15” floor-to-focal-spot distance) and skull exams for adults. The system’s main C-Arm rotates 180º, and includes auto stops at 0º, 90º, 135º, and - 45º. The image receptor rotates within a range of +/- 45º to provide for various studies.
SAFETY
Collision sensors are designed into the electronic movement controls, for both vertical travel and C-Arm positioning. In addition, the receptor unit includes a “collision sensing bumper” designed for additional safety
40”- 72” VARIABLE SOURCE TO IMAGE DISTANCE
The QV-800 provides a variable horizontal source-to-image distance (SID) of 40” to 72” (100 – 180 cm) to accommodate a range of radiographic studies. Once the C-Arm is angled into the horizontal position, the x-ray tube assembly can be easily moved from 40” to 72”, by using the operator hand control.
POSITIONING FLEXIBILITY AND EASE OF USE
The remarkable flexibility of the QV-800 system makes patient positioning and system adjustment quick and easy. The x-ray tube source and the image receptor remain in constant alignment for fast and accurate imaging. The system’s operator-friendly controls, dual speed motorized movements, and collision sensing electronics enable smooth, single-handed operation.
650 POUND PATIENT WEIGHT CAPACITY MOBILE EXAM TABLES WITH FLOATING TOP ADJUSTMENT
The QV-800 Universal system simplifies recumbent exams through the use of Quantum’s QT-711-QLW and QT-712-EV Series tables, which can accommodate patients up to 650lbs (295kg).
Main C-Arm Rotation Assembly:
Main C-Arm Vertical Assembly:
Operator Handgrip Control Unit:
“TechVision”: (QG-TVC) - (OPTIONAL)
Variable Source-to-Image Distance (SID):
Image Receptor Assembly:
X-Ray Tube Head Assembly:
1) Includes Power Supply for QV-800 Unit
2) Left hand loading only available (image receptor on left side)
3) System available for Direct Digital or Conventional Film receptors
